I just found this enlarger on craigslist. It is an Omega B22. I am in the process of building a darkroom space in my basement so I will obviously need an enlarger.
http://knoxville.craigslist.org/pho/1334698736.html
Is it worth buying?
Used one for years, sold them at the shop I worked at.
They came in a package with two Omega lenses on lens boards, of medium or less quality, in the old smaller diameter mount, so if you want to put a more recent hi quality lens on it, you will need to adjust the mounting board. Modern enlarging lenses I believe are Leica Thread Mount.
Also had film holders for 35mm and 6x6cm included.
APO is always a welcome mark on an enlarging lens. ;-)
The old coatings on the Omega lenses were soft, and would dissolve in alcohol-- I found out, when I cleaned the lens with "lens cleaner" .
Not much point in shooting with a Leica and printing with a cheap old tech. lens. A modern Nikkor el, or any APO will show a difference.
They also came with an auxiliary condenser that sat on top of the regular condenser, for use only with 35mm, it just drops in when you take off the top.
Sometimes the adjustment knob that locks the height broke, it was aluminum, a known defect, and Omega replaced them. If it is stripped or broken, it will not hold its height.
The normal base was just too small, but it was very easy to fabricate a larger one from a piece of counter top, it used standard mounting nuts.
The aluminum beam was nice, light, and the motions were smooth, make sure the counter balance spring is intact.
Still, it is a compact, decent unit, easy to use, but -- you want all the pieces that came with it, and any other stuff he has lying about to sweeten the deal, timers, trays, lenses, etc.
Price is not particularly good, a lot of these are given away or tossed. Without all the parts, not a good deal.
Vintage, -- 1960's, new price, $125.
With a good lens, larger board, you can make good prints with this.
Last I heard, Igor had an enlarger in the garage waiting for someone to take away, heck, there is one in my garage, ;-).
They really tend to last as long as you want them to, and the lenses easily cost more than my 45m Beselers.
Did you check Freecycle?
Regards, John
