pabaker34
Can anyone say how the Kobalux compares to the Voigtlander or the Contax Biogon? I know the Voigtlander is only f4 but as far as sharpness, distortion? Thanks in advance!
Akalai is correct. There are three generations. The third generation is considered the "best" lens. I have the second generation which also has a short focus throw, 0.9M closest focusing distance and 6 aperture blades. I understand the major differences between the two versions are closest focus distance and some adjustment in the optics to allow this. I believe that optically the 2nd and 3rd versions of the lens are otherwise very similar.akalai said:Its my understanding that there were at least three versions of this lens and that supposedly there was an improvement both in optics and build quality in the 3rd generation lens. The third generation lens has the short focus, .7m compatibility and has 8 aperture blades....although I am not sure how many the earlier versions had...
My Kobalux 21mm is from the third generation. But I wouldn't assume because my particular lens has an issue (front focus) with my particular R-D1 that all samples of this lens have the same issue. I've used my Kobalux on other cameras, two Leicas and two Bessas, and haven't noticed focusing discrepancies with any of them. This includes a careful lens test on my M2 after first noticing the problem on the R-D1. It may be my R-D1 is slightly out-of-spec in a way that only manifests itself with wide lenses. Dunno. I may have DAG take a look at it to be sure.
jlw said:Have you read the thread I just started about variations in screw-to-bayonet adapters? An adapter that's too thick would cause wide-angle lenses to front-focus, and the wider the lens, the more the deviation would be.
