Jim Watts
Still trying to See.
Thanks Mike,
A tripod is better if only to check for repeatabilty. See my comments in Chris's "Just purchased a Leica 90mm APO-summicron-M lens" thread, but I have done it handheld as you describe as this is more like a real world situation. Could I suggest though that you try with a focus point of a little over 1 meter (got any more Leica Mags. to extend the run? 😀 ) using the focus ring to achieve focus as its common for some lenses not to couple properly to the rangefinder close to absolute minimum focus point.
I have just now tried David's infinity test on my 35mm f/2 Cron that front focuses. Focused on about 50ft wide open (f/2) it seems just a little sharper at the correct focus distance than when reset to infinity. So the problem is only close up in my case. Although I can see the difference in David's posted pictures hopefully a few more tests will confirm the Deadstock you have found us is better, but if not I think in most of the shooting situations I would use the lens in it should be O.K. And I pretty certain the problem would not occur with my M4, although this is being sadly neglected these days.
