iandg
Iggypops
Hi i have been told that you cannot use this lens on the canon 7 or P because of the large rear element of the lens i would be gratefull for your input on this one.
Ian
Ian
airds said:We've covered this subject loads of times - search this forum.
iandg said:ive done a search but to no avail thanks to those who are giving me positive advise.
airds said:Are you searching the 'Canon Rangefinder' FORUM - not just this thread? If I put
Jupiter 12 Canon
in the Forum search box - I get 5 hits, with a total of 76 posts which will tell you all you need to know ..... so pretty d*mn positive if you ask me
iandg said:Thanks everyone it seems the newer version lens may fit and if it does not i can always use it on my bessa or i may hold out for a canon 35mm.oh and Airds your quite right i was searching for jupiter 35mm canon so thanks for the positive info ps your lucky living in such a photogenic part of the uk i visit every summer while holidaying in the highlands.
FrankS said:Nope, same problem!
iandg said:Thanks Frank im not going to bother with this lens i will keep the money towards a canon you can tell i have a lot to learn but thankfully im learning on this forum
You shouldn't have any trouble with the FED and J12 combination. FSU(Former Soviet Union) lens and FSU camera work well together. You will probably want an auxiliary viewfinder, though.johnbay said:I know this subject has been discussed on earlier threads but the only one that I could find was from March discussing mounting this lens on a Canon RF. I am considering purchasing a J12 to use with my Fed 2d. One is up on the auction site built in 1961. Various reports suggest purchasing a late model example to avoid mounting problems. Is 1961 considered early or late model? Should I be concerned or does the J12 usually mount well with Fed 2's? Again, is it just lens to lens variability? Thanks in advance.
johnbay
iandg said:Thanks everyone it seems the newer version lens may fit.
airds said:Colyn
I thought we all seemed to have agreed on later versions fitting on Canon bodies - see this thread - anything specific about your lens I wonder? My '76 version fits on my VI-L & 7 fine.
