bigal5567
http://www.kyphoto.com/classics/canonetblade.html
i found this. is this what i need to do? if so, it doesnt seem hard.
bigal5567
also, what exactly is the rear element?
Kim Coxon
Moderator
If you have a hunt through the threads on this forum, there have been several threads with information of how to clean the shutter and get it working. I can point you to a copy of the Canon repair manual. (It's on my website). If you end up with any problems, I am sure someone here will be able to help.
Kim
Kim
bigal5567 said:alright, so sounds like sticking it in the oven is bad.
but if a repair is gonna cost me 100$, forget that. i'll google stuff, and see if i think i can handle it.
if i cant fix it however, i'm sad.
thanks
-alex.
Kim Coxon
Moderator
Most find it easier to take out the front element rather than the rear one.
Kim
Kim
bigal5567 said:also, what exactly is the rear element?
bigal5567
oh really? i found a bunch of stuff saying to take off the rear element which i now realize is the glass in the back. i can see the shutter through that, and it makes sense that i could swap it with some lighter fluid till it frees. but getting to it is weird.
i'll take a look at your site,
thanks again
-alex.
thanks again
-alex.
bigal5567
and your links on your site arent working?
Kim Coxon
Moderator
Sorry, a glitch on the server which hopefully should now be fixed. The repair manual is here http://pentax-manuals.com/repairs.htm
and the operating manual is here http://pentax-manuals.com/manuals/range/range.htm
Kim
Kim
bigal5567 said:and your links on your site arent working?
bigal5567
alright guys, real sorry to bring something this old back up, but.
i havent had much time at all to do anything with the camera, but this weekend, i plan on conquering it. anyway, i now understand the deal with this camera. the front has to be taken apart using a spanner wrench, i'm not sure where to get one of these? then the blade is cleaned with a lighter fluid type deal. alright, sounds easy, its not.
it took me the longest time to figure out how to get the thing apart, because every site i saw just assumed i knew how to do that. but i get it now. i just need one of those spanners, where'd you guys get yours and is there anything else i could use thats maybe more readily available? i'm so ready to get shooting, but this is holding me back.
i might try heating, that makes sense too, but sticking stuff in the oven, other than food, just doesnt seem like a good idea?
Bobfrance
Over Exposed
I used a pair of needle-nosed pliers on mine. Luckily they were a bit stiff and in need of oiling which helped keep tham open in the correct position.
I opened them up so that the points of the pliers fitted into either notch in the ring that retains the lens. I then very genty turned them.
Be really careful not to slip - you don't want any scratches on that lovely lens.
Good luck!
Bob.
Good luck!
Bob.
bigal5567
alright, i get it. i'm going looking in my garage to see what tools i can find. needle nose pliers? i know theres some in there, and i guess grinding down the tip of them would help?
alright, once i'm in, i post again letting you guys know whats up. damn, i'm stoked.
Al Patterson
Ferroequinologist
Good luck with this and let us know how it works out.
Bobfrance
Over Exposed
No news yet?
