Mackinaw
Think Different
- Local time
- 8:30 AM
- Joined
- Mar 13, 2005
- Messages
- 4,762
Youxin Ye.
http://www.yyecamera.com/
I don't believe Youxin Ye works on the Canon 7 or 7s. His website suggests he only works on earlier Canons.
Jim B.
Youxin Ye.
Jim B.
For rangefinder focus accuracy test you can do the ground glass/matte-finish tape + magnifier trick.
If the focus scale on the Canon doesn't match up with the actual distance, and the rangefinder is wrong too, then the problem may be that there is a shim missing from inside the lens. My 50/1.9 Serenar was missing a 0.28mm (from memory) shim, presumably lost when the lens was cleaned before my ownership. I replaced it with a shim from a Jupiter-8 lens which was surprisingly exactly the right dimensions.
Confirming Jim B's comments on Youxin Ye's work on Canon 7s. Just had an internet chat with him about this earlier this month. He will not work on 7s.
You're going to like that little 35mm Canon lens. I have one like it and use it all the time on my Sony's. Great little lens.
Still need to find someone to CLA the Canon 7. After I used the shutter-speed app (along with a photoplug addon) I'm getting about these readings (flashlight on back of the camera, photo plug sticking into the opening of the lens mount to keep it out of the light)
Set = actual
1 second = 1/1.3
1/2 = 1/2.1
1/4 = 1/3.3
1/8 = 1/6.1
1/15 = 1/17.5
1/30 = 1/26.6
1/60 = 1/47.4
1/125 = 1/92
1/250 = 1/153.9
1/500 = 1/227.6
1/1000 = 1/289.5
That's IMHO not bad at all. It's unlikely that it can be substantially improved, unless you spend quite a lot of money. I would leave it alone.
Since you have taken the top plate off and the bottom plate is easily removed (couple of screws and the black ring around tripod mount, IIRC), you should be able to clean up any old hardened grease and replace with new lubricants at the shutter pivot/rotating points.
