K
Kin Lau
Guest
I'm quite disorganized as well, so these suggestions might work quite well for you 🙂
10,000 pics on file, at 6megs per image is only 60gigs. Just keep CD's as backups but keep the actual images on the HD. Retrieval would be _very_ fast compared to CD/DVD's. If you want to keep 1meg jpgs as thumbnails instead, then you can easily keep 100,000 pics on a 100+ gig HD. If you keep your scan folders organized the same way as your filing system and CD's, then you'll end up with an electronic "visually organized" system. I don't know how Nikonview works, but Zoombrowser (Canon) and Irfanview both let me see a list of folders on the left, and the thumbnails on the right, and I can scroll thru 100's of pics very quickly.
Other suggestions: a fully rez tiff scan of a slide is probably around 24-36megs each, so all 24 slides will easily keep on 1 CD. Just store the CD with the slides. You can also buy hanging sleeves for CD's, 4 or 6 CD's to a sheet/page for ease of storage.
HD storage is down to only CDN$.75 per GIG, so consider using CD/DVD's only as storage, and get a few 200gig hd's (even removable hd's) as near-line or online storage.
