Dourbalistar I wonder about your development times, they are quite a bit shorter then the 8 minutes prescribed by Ilford for their HC developer, which from my understanding is the exact same as your preferred LegacyPro L110. Do you expose at 200 or do a lot of agitation? I have developed for 7:30 with okay results, maybe a bit low on contrast. Your images look well developed with good contrast so I'm curious about the process. Maybe it's that California water...
Thanks, lukx! LegacyPro L110 is a clone of Kodak HC-110, but I'm not sure either are exactly equivalent to Ilfotec HC. Ilford's data sheet for Kentmere 400 only lists D-76 times for non-Ilford developers, but if you look at the data sheet for HP5+, the suggested developing times for Kodak HC-110 and Ilfotec HC are different.
FWIW, the Massive Dev Chart (taken with the salt required) times for Ultrafine eXtreme 400 are 5 minutes for HC-110 and 8 minutes for Ilfotec HC. Personally, I'd settled at 5.5 minutes in LegacyPro L110 for UFX 400. Since people seemed to think the two film stocks are identical, I thought I'd at least try the same developing time with Kentmere 400 to start, and see if that bore out in my workflow and results. Still too early for me to say since I've only developed one roll so far, but I'll keep posting my Kentmere results here.
Results look great. But as others have pointed out, a side by side comparison would be more valuable than lots of (terrific) individual images. As Lukx has noted film developing times vary - water quality, agitation technique, thermometer calibration and even when you start and stop the clock will all contribute enough variation so that my times may be significantly different than yours. It doesn’t matter as long as you are consistent with yourself at every run. Again, nice work, makes me want to try some Kentmere.
Thank you, KenR! I don't enjoy testing for testing's sake, so I haven't done any side-by-side tests. When trying new film stocks, I just shoot them as I normally would. I guess I'm less concerned with knowing for sure whether Ultrafine eXtreme 400 is identical to Kentmere 400, and more interested in whether or not I like Kentmere. If I like it, I'll keep using it! Considering that UFX 400 may be discontinued, that point may be moot.
Of course, like you said, there are lots of variables. I'm comparing my results in a workflow that I control, so at least there's a measure of internal consistency. That said, here's a side-by-side comparison that you might find interesting:
https://stephend.photo/kentmere-400-vs-ultrafine-extreme-400-10172019
