Roberto said:
Hi Ruben,
How does it react in backlight? is it prone to flare? Do you also have a J8 or J8M? Would you mind posting some comparison shots? I love the J8M and I was wondering whether this extra stop is really for free or the J3 quality is worst..
Thanks,
Rob.
Hi
Roberto,
Along the years I have assembled a kiev fleet, with a dozen standard lenses of all the types.
Although I am not an expert, and far from that, I have the feeling that besides a really crappy lens, all others may show between good and superb according to the specific Kiev camera they are mounted on.
The test of full apperture and close distance is very difficult to perform with extreme accuracy, if you want to test all of them on the same camera/roll of film. I have done it in fact, and will continue whenever I will change the Kiev in actual use.
But the results cannot be but approximate. The DOF is miserable. Then you have the problem of ensuring that all lenses will be tested at the same point in the distance scale, and related to that, mounting and dismounting standards on a Kiev is perhaps unpossible to do without mooving the tripod by a tiny bit. But every tiny bit counts in this field, in which you are spliting hairs.
Therefore in this complex situation, as in other Kiev accuracy related, like rangefinder accuracy, I go by the path of the acceptable and avoid going crazy. I do my best within what is sensible logical.
I am using now two Kievs 4AM, which by an educated guess we can assume are not the most accurately built also in terms of mount to film plane distance. Therefore I did my all lenses tests and found that the best was a 64 J-8M, followed by 2 Helios. I am aware that by more severe testing I may have arrived to somewhat different conclusions. But I want to make pictures, and gossip at RFF as much as possible and not go crazy.
In a previous test, some years ago, on behalf of a Kiev IIA, a J-8 surpassed on the same film my Zuiko macro 3,5.
I think that owning a 1,5 lens is worth for the 1,5 aperture first of all. In my opinion this half stop extra over the Helios, is somewhat psychological and sometimes usefull. Sometimes you find yourself scratching light, so to speak as to illustrate the need of maximum possible apperture.
In my case it is somewhat more accute as I am not sure I can obtain a sharp shot with a standard at 1/25, This is due both to my hands and to the fact that I am still a newbie in the streets, becoming tensioned when the opportunity appears.
But in terms of manipulation I prefer the smoother and double scaled Helios, and then the J-8M for its double scale. J-8 and J-3, witout clicks, and single scaled, are not the most comfortable for me.
As for flare, I have never used any lens of any type for any camera without a hood, and this pictures here are just my first roll with this J-3.
As for this specific J-3, upon the reactions of the members, and taking into consideration the shots were at f/1.5 on an overdeveloped film - I think I have bordered the possible worst, and if this is within the acceptable to me, then further shots will be only better.
Ruben
