S
StuartR
Guest
Huck Finn said:I like most of what I saw on the Konica Hexar RF. I decided not to buy it because I didn't want the low magnification (0.6x). Despite this magnification, Konica chose to clutter the viewfinder with 135 mm frame lines despite the fact that such a lens is virtually unusable at this magnificaiton. Even a 90 mm lens will have focus problems at f/2 on this camera. The parts/service issue also scared me off.
I would disagree with your statement that the 135mm lens is unusable on the Hexar RF. I used a 135/4 Tele-Elmar with it in Iceland and had no problems at all. I mostly shot at f/4 and f/5.6. Here are some samples:
It works fine, you just need to be attentive and careful. As long as you use good technique and have decent eyes (or contacts like me...) you should have no trouble focusing the 135mm lens on the Hexar RF. I did not have many problems with the 75/1.4 either, but I did not shoot it wide open and close up very often...that is hard to focus on any body.
