They have been used for years in aftermarket, and homemade, products for diffusion enlargers, ever since extra-bright LEDs became available. There have also been variable-contrast heads made. A straight plugin replacement would have to have the same size and shape for existing heads if you were going to swap it in there, and be much more powerful too.
Another solution, as used in cold-cathode heads, is to have an always-on light-source with a shutter of some sort, so maybe a custom head with a larger fluorescent could be made - but there would be colour temperature problems as those lamps are do not have a continuous spectrum output.
In the discrete-LED based heads the older the design was then the more LEDs were used, due to brightness and evenness problems, but I suppose that now it should be possible for someone to come up with a very simple design - or it would if there was any r&d left in the enlarger business, as most of the original manufacturers have gone broke or diversified. 🙁
