NB23 said:
This is odd! Altough Leica didn't design the Epson Camera's rangefinder, I think it's irrelevant to talk about it and its short base. But if you insist...
If you use both lenses on a rd-1 and focus on a subject 10 feet away, the difference in DOF is only 0.12 feet (0.53 feet Versus 0.41). This is such a small difference that I doubt you would see a difference in real life.
If you don't get a dependable focus with your 90 and yet you are always in focus with your 75mm lens, the one and only reason is that your 90mm lens is miscalibrated.
Not to put too fine a point on it, but I disagree ... a lot. My experience with both the 75/1.4, 75/2, and 90/2.8 on a Bessa and an M7 is different. I think the facts are best interpreted this way (all data at 10 ft & wide open):
1. On a RD-1, the cron gives 40% more focus cushion (.42/.3) vs the lux. Same for the 90/2.8. The summarit gives 77% (.53/.3) more focus cushion than the lux.
2. In 35mm format, the cron also yields 40% more focus cushion than the lux (.63/.45). About the same for the 90/2.8 And the summarit over the lux gives you, again, about 77% (.8/.45) more cushion.
(Carl is right, I believe. The DOF increases by 50% when you move to 35mm from the 1.5x crop factor of the RD-1, making its comparatively short baseline even more of a factor in focus capability.)
At any rate, my experience is that I could not focus the 75/1.4 wide open on a Bessa reliably, but could do so with a 90/2.8, a 75.2.5, and the 75/2. I can focus all of them on my M7, but feel more confident with the latter three lenses than the Lux.
Then again, I'm 53 and my eyes aren't what they used to be ... and they weren't too brilliant then.
I know I'll probably sell the 75/2 and revert to shorter lenses as aging takes its toll. I do like the 75-90 focal length though. That Summarit is looking ever more attractive: size, weight, handling.
