charjohncarter
Tom, thanks again for your expertise on LTM cameras. I started with a IIIc with a Summar f/2, so even though I only had it for 1 year it was my first real 'camera.'
Amazing!
How many times is this seller going to sell this camera I wonder?
http://www.ebay.com/itm/Leica-IIIcK...676879373?pt=Film_Cameras&hash=item2eb9462c0d
It has been on evilbay now I think 4 TIMES! ~ Not correctly advertised, not correct lens which he sold last time as the original, yeah here's a heads up to stay away from this one 🙁
Too bad
Tom
Any thoughts on ebay item 230623865882 ?
SN is close to both my chrome IIIc cameras. Could this one already have had bearings in the shutter?
Cheers Tom,
So Leitz ran out of chrome somewhere between 382xxx and 387xxx then?
Hello, I recently bought a Leica IIIc with serial number 375164 (red curtains) with an Elmar 5cm #533010- average wear, but pretty good overall (none of the usual rusty spots inside the body, and the lens has minimal cleaning marks). Any information would be appreciated. The Elmar has a nearly 1/2 inch notch out of its front rim- possibly for an adapter of some sort?
Thanks, Tom. Do you know if this was issued to a civilian or to the military? The camera has recently had a CLA; running the first roll through this week.
Hey Tom, your former 391xxx is currently undergoing a CLA, mainly to see if the capping on the faster speeds can be fixed.
It contained some hardened lubricants that didn't look like regular oil or grease. Possibly this is the original synthetic lubricant, which would indicate it never underwent maintenance after it left the factory.
Some seals are made from very thin sheet metal.
Some extension steel springs are substituted for simpler blade/leaf springs.
Cleary some corners were cut here and in other parts of its construction of the camera to quickly fill the demand for cameras by the occupying armies.
There were also plenty of film chips and a single small glass shard in the gears.
The shutter drum wasn't taken apart (the curtains are worn but good, no real need to replace them), so no confirmation if it truly is a "K". I'm still taking your word for it 😉
She'll should be back in action shortly! I'll ask about sharing some pictures from the CLA.
I picked up 3 Grey K's this weekend with the shells complete, original lens and 2 have Grey cases. Found them at K-Mart 🙂
