Leica M v Nikon D750 comparison
Nick De Marco
8:01 PM
For those interested I just published a comparative review of the Leica M and Nikon D750 and some of my favourite lenses on each camera: http://rangefinderchronicles.blogspot.co.uk/2016/06/a-day-out-at-leeds-castle-nikon-d750.html
I like both cameras (the D750 is new to me, the M I have enjoyed for years) very much, for different reasons - so my review does not suggest one is better than the other overall, but rather each being preferable tools for certain things, or for certain reasons, and both being very capable of making excellent images.
Nick
Interesting. W/re. to the summicron being 'warmer' than the lenses on the Nikon, I think that that is more a result of the Leica's auto colour balance. I find it very variable on mine, siding to the warmer end of the spectrum.
In the photos, yes, the software is much more important, but if you use a reversion spectroscope and a colour controlled light source you'll see Leica lenses are warmer than most othes. Erwin Puts notes this in several of his reviews. Choice of glass and coatings are important for colour transmission.
Marty
The series would be much better if auto WB were turned off, both cameras.
I will concede Japanese lenses have a different color signature than Leica but a Whi Bal card will go a long way towards evening things out. Set a sunlight balance and save it. D750 and M digital will accommodate.
Either shoot raw or set camera JPEG engine to give the same results. All controls are there.
So, the lens is the first signal filter in the data stream. In this case the signals are the frequency and amplitude of the light entering the lens. Obviously this assumes a lens filter is not present. Different lens coating formulations filter the signals differently. The sensor photo diode sites (pixels) can't record signal frequencies filtered by the lens coatings. Lenses often have a significant impact on color rendition.
For JPEG users the in-camera raw to JPEG rendition can significantly affect color rendition. Auto WB may or may not be optimal. Unfortunately the JPEG compression destroys much of the information needed to manipulate color temperature during post-porciessing. However in-camer JPEG presents do offer some flexibility to alter color rendition to one's taste.
Raw users usually start the post-processing rendering using the camera's WB parameters. All the data is present in the raw file, so there is no limitation on adjusting the global color temperature. In other words the camera's WB setting doesn't matter. The lens coatings do matter to some degree because the light was filtered before it reached the sensor. Even the raw file does not have all the information (signal content) that entered the lens.
Still, post-processing can cancel the affect of lens coatings. In Photoshop (and other products) one can create a global layer that cancels the lens filtering. It may be tedious to create a layer that replicates a certain lens' color temperature bias, but once you do it the process can be automated. This is no different than adding physical color filters to color print enlargers. In both cases you are adding the signal information removed by the lens coating.
Discussions of color rendition differences between different brands, different models within the same brand and different brands with different lenses are difficult because so many factors affect the final result.
Yup. A better lens comparison would be to shoot them both on the same body to show colour characteristics. With a $30 adapter from Fotodiox (which works brilliantly - I use one) the Nikon lens could have been shot on the Leica.
With auto white balance and lens coding off, we could then see the colour differences. Or at least a more accurate take on it.
But.. it doesn't matter in the big pic as it can all be adjusted to suit in post.
I shoot weddings with an M 240 and a D750. The D750 absolutely has a better sensor in terms of noise and dynamic range. I'm hoping Leica will catch up in this regard this year. But in practical terms this just means I shoot for a tighter exposure with the Leica. The Leica also tries to throw out a lot of dynamic range SooC, so there is a lot of headroom in the highlights. I suspect they do this to 'wow' enthusiast customers who want a more edgy look, but I'd rather have a flat file personally.
As for their use and performance. The 240 has exceeded my expectations in many ways. But they are SO different in operation that it's hard to compare. A Nikon is a Nikon and a Leica is a Leica. You just work to the strengths of each.
I'm fine with the way the cameras/lenses were tested. If that's how the photographer - and many others - typically shoots, then setting to a custom white balance and such doesn't make sense.
Both cameras are excellent machines capable of producing fine images. Like the OP, I found the D750 better for longer lenses and faster in operation. But also liked the size and user experience of the M 240. But, being the fickle photographer I am, sold both!
I just shot a wedding last weekend using my m240, 28 1.9 ultron and 50 plannar along side my canon 5DSR. I have to say that using the M for getting ready shots as well as during the reception was very good. It felt like I was less encumbered and focusing with the lenses in the dim light was not a problem at all. Like what some of the others have said, you gotta use the camera in the right situations.
extra work and JPEG is not as adjustable as raw.
I have put Leica and Nikon lenses on a D800, changed nothing and used manual WB. The Nikon lens is green.
I recently bought a D750 and can compare it, sort of (as I don't shoot them the same way) to my M240.
The sensor on the D750 has much better high ISO, and its files are far more flexible.
The auto white balance also seems much better. It can take fantastic pics.
It also is far less rewarding to use. It's kinda taking the fun and satisfaction out of photography for me. If I wanted easy, I'd just use my phone.
