Leica M5... good choice?
50/1.1 is a stretch for the M5 meter. At full aperture the M5 meter gives slightly wrong readings also with the Noctilux. The reason is that the diameter of the rear element is to large and therefore not all light hits the CdS-cell located in short distance behind the rear element. When the M5 was constructed the f/1.4 lenses were the fastest lenses available so that is the M5 limit.
Well, besides two M2's and the upcoming M5, there is an M9 in the cabinet and somewhere around here is a R6.2 with a few lenses.
I had ordered a 50f1.1 yesterday but cancelled the order. I have never even handled an M5 so first things first. I have two weeks to return it if I do not like it. And since it appears to take all my M mount lenses including the 15 and 21, I may have enough of them at the moment.
50/1.1 is a stretch for the M5 meter. When the M5 was constructed the f/1.4 lenses were the fastest lenses available so that is the M5 limit.
Gabor, this statement is incorrect. The M5 was constructed for use with the Noctilux 50mm f/1.2. This lens was introduced in 1967.
Personally I've seen no wrong measurements when using the M5 with the Nokton f/1.1. On the contrary.
Erik.
Erik, you are correct, the 50/1.2 was actually introduced 1966.
I had problems metering with Noctilux at f/1.0, though.
Erik.
The collapsible Summicron can be collapsed safely on the M5. Equipped with the 12549 shade from the Elmar-M it makes a nice compact set.
Erik.
Are you sure the Cron 50/2 collapsible can collapse safely on the M5? I just want to be sure before I put it on.
Thanks,
absolutely
I don't own this lens, but it's on the "do not collapse" list.
I own it but it does not seem to protrude as much as my leica 21/2.8. I want to be sure before I put it on.
Pepe, I collapse mine on my M5 without problems. Just try it to collapse VERY carefully if you want to be sure.
Erik.
I can assure everyone it is OK to collapse the 50mm Summicron on the M5. I took very careful measurements on mine. I made a depth gauge from heavy card stock to test the dimensions. There is enough clearance with the lens collapsed. Here's what you can do if you want to check for yourself. With no film in the M5, open the back. collapse the lens slowly while you watch through the back door. The lens barrel will bottom out before it reaches the meter stalk.
Maybe because of the extreme cos4 vignetting of the Noctilux f/1.0. The Nokton 50mm f/1.1 suffers much less from this problem. This is explained a bit in the Leica M book by Osterloh, German version, 1986, page 40: "Beim Noctilux-M 1:1/50 mm und Noctilux-M 1:1.2/50mm erfolgt eine korrekte Belichtungsmessung erst ab Blende 1,4 und kleiner." On page 44 Osterloh states that this problem also occurs with the M6.
Erik.
I am thinking about this. The vignetting becomes visible at the film gate position but the CdS-cell is located closer to the rear element. Therefore it might not register all of the light at this position.
Erik.
Yes, it is a kind of spot meter, but the closer it gets to the optical elements, the indecipherable it becomes what it actually mesures.
Erik.
Leica M5, Summilux 35mm f/1.4 pre asph v1, Tmax400.
Erik.
Erik perhaps you could answer this but I've owned my M5 for almost 5 years now and I've never quite understood why there is a B1-B30 setting on the shutter speed. Is there actually any use for it or merely cosmetic.
