Axel
singleshooter
And the Sony can take the Leica M lenses.
I'm not a fan of m4/3... I have a personal bias against the m4/3 and love for digital fixed lens leaf shutter cameras 🙂
2c
Can't handle?Sony is digital alternative for those who can't handle true RF.
I'm curious about your dislike of m4/3 -- can you elaborate?
Can´t be wrong.... I enjoy the photography and not the cameras ...
Hi Raid, my wife Simo modeling when I tested my friend's Pen F, iso 400 lens was 17/1,8 full open.
And do not forget that the camera is a beauty!
In my case I can't stand the native aspect ratio.
Second, internal optical finders are unavailable. I can't use a m4/3 camera as I use to use an analog RF camera. I enjoy seeing what's outside the frame.
A less important issue for me is the system lenses have to be large unless you don't miss using wide apertures. Besides the obvious impact on DOF, in low light wide apertures deliver more total signal. In low light both the total signal level and the noise level determine perceived image quality. The problem isn't the noise level, its the signal level. This also affects shadow region reninding in normal light levels.
Larger sensor surface areas require larger lenses to produce a useful image circle. However looking at relative lens sizes for fast 4/3, APS, and 24 X 36 mm cameras indicates the the lens surface area is less important as sensor area increases.
At any rate, there is no free lunch. A system's maximum S/N depends on both the lens area and sensor area. Overall, S/N increases as the square root of the sensor area increases. So the only way to match the low-light performance of larger sensors is to increase lens surface area (i.e. size, weight and cost).
Here's some data comparing low light performance for different sensor areas. These results show the newest Olympus sensors do very well.
Her's a comparison of analog dynamic range vs sensor area. This assumes the photo-site sensitivities are identical.
Don't forget..M 4/3 you can use all those cool tiny lil cine lenses..sometimes for hardly anything..and a real different look...
