silverbullet
The Leica boutiques all over the world are full with digital Ms in front of X-Mas. Can we expect an official statement before the arrival of Santa Claus and Rudy the Red Dot reindeer? 🙂
The Schott filter is extremely thin and efficient. It's not clear there is an alternative filter available. This is why, at the moment, some people think the replacement sensors' filters have the same susceptibility to humidity.
Benjamin,
The evidence right now is the parts Kodak supplies are not the problem.
The problem is either the Schott IR filter and its protective coating or the protective coating on the cover glass. Since the M9s' Schott IR filter's spec sheet states the filter is susceptible to humidity damage, the IR filter and, or its protective coating is believed to cause most of the degradation problems addressed by Leica's new replacement/repair policy.
Thanks for that clarification. Hope a permanent fix is possible . . .FWIW, I live in Vermont, which is not a particularly high humidity area. Or put another way, if central Vermont is humid enough to cause a problem, it is hard to imagine a US location that won't have the issue. That said, it is odd to chose a component with that sort of weakness for world-wide sale. Bizarre.
Ben
Ummm.. Kodak sold off the sensor business long ago to Truesense, who have sold it on in their turn fairly recently. Where the liability went in this chain is unknown.A year ago, my M9 began exhibiting odd-dustlike spots along the upper edge of my pictures. It looked like a set of several hundred spots. Problem was, they were always visible on any patch of sky . . . which was to say often in outdoor shots. I had never cleaned the sensor on this camera. In fact, I try not to touch any of the sensors on any of my digital cameras. I tried canned air. No dice. I went into a photo shop in Paris, where I was traveling when the problem asserted itself and used a compressor. You know how the story goes. I tried pads with PEC cleaning fluid. Also no dice. Finally, I bit the bullet and sent the camera to Leica NJ. To my surprise, they replaced the sensor at no charge. I had the camera back within a month and it has functioned well since.
Reading this (lengthy) thread, it helps make sense of what happened. And it is a tough spot for all of us. There is obviously a flaw in Kodak's manufacturing process, or in the product design, but Kodak is in bankruptcy and there is no help for Leica there. I would guess (on very little information) that replacing sensors for the life of the body is not a feasible option for Leica. It might be the right thing to do. In fact, if they have produced a defective product, they might be required to do so. But if I were an executive at a small company like Leica, I would probably see whether I could get away with a non-Company killing option first to address the problem. I am also assuming that unless you want to go back to square one and re-write all the firmware, you can't replace the current chip with a CMOS chip from the the current camera. So they are doing the best they can.
I have been an avid photographer for the last 30 years or so, and my M9 is easily the most expensive piece of equipment I ever purchased. More expensive than a Sinar F1, more expensive than a new Nikon F4, more expensive than a Zone VI 8x10 field camera with a new Nikon 300mm W lens (whoo, that one made me sweat), more expensive than any Hasse1blad (which, admittedly, I bought used). No question that it is disappointing to read that this incredibly specialized and expensive piece of equipment has a flaw like this, and that there is no easy fix. I plan on using mine until the "wheels come off" -- I really like the files it produces. At that time I will look about me and see what the options are.
Ben
Well, everybody is between a rock and a hard place. Leica needs to protect its reputation, but has a limit to the amount of money they can pump into this one. The two shareholders (ACM and Blackstone) cannot afford to let a profitable and growing company go down the drain because of an one-off problem, ACM Projektentwicklug ( the probable owner of the two factories) cannot afford to lose the tenant to two spanking-new facilities that are wholly unsuitable for any other purpose, the customers cannot afford to lose the producer of an unique system, the the possibility to pass the whole mess unto the parts supplier is doubtful for a number of reasons...I understand your "ummm" to mean that any git should have known this. I suppose you are right. Apologies. Feeling a bit prickly tonight. Sounds like most of my assumptions are incorrect. Happens all the time. Difficult to get out the front door sometimes. Really. OK. Forget what I said. I guess we'll all just wait and see what happens.
There must be a solution/compromise somewhere that is being sought as we write.
Let's see what this week brings.
Compromise?!
I though we have laws around here in EU regarding the consumers protection.
Who cares about the shareholders, the EU legal entity has brought product to the market and it has design flaw.
They have to repair or disappear from the market if they cant.
Which is not to imply that I don't use plenty of digital. But when I want to ride my bicycle I don't put a motor on it.
Not very helpful, what are you saying warranty-wise?
Leica involvement in new stores and Leica NJ is certainly not all that transparent -- not sure I would call Leica in NJ just an "importer." The financial reporters like Bloomberg may have it wrong, but they seem to believe Solms is heavily involved.
What insurance? Are you suggesting they should set fire to the factory?Sounds like there could be up to 80,000 cameras potentially affected out there. 😱
Would have to agree. While "compromise" is good, and surely what will happen... The shareholders are the least of the worries. If this isn't handled well, the bad publicity and ill-will towards the company will ensure it's demise just as surely as replacing every camera might. Besides, this is what insurance is for.
And what will happen to the cameras we all have if they disappear? And to the rangefinder style of photography? The customers have a stake here as well, I should think.Compromise?!
Maybe a thicker higher performance IR filter is the solution, and from my experience this would also offer a performance benefit. This could be the answer/solution to the design defect. Leica are you listening?
Cal
Regrettably the thickness of the filter stack has a profound effect on performance of the lenses. Replacing the suspect filter with a same thickness but uncoated one should work, then requiring the M8 filters you never got around to selling 😀
http://www.lensrentals.com/blog/2014/06/sensor-stack-thickness-when-does-it-matter
