Best Monochrome Options 2025 - Leica? Converted Files? Converted Cameras?
For a different perspective -- I chose to forego dedicated monochrome cameras in favor of just using my regular color camera and doing b&w conversions from the color dngs. I'm not denigrating mono cameras, in fact I think they are terrific under certain conditions. There are certainly advantages to using monochrome when conditions are optimum, but, often they aren't, and in those cases there can be significant limitations or hurdles to overcome when trying to get an acceptable image from the mono raw image. This commonly comes up when doing landscapes or architectural exteriors where there is a the need to adjust tones like darkening a blue sky.
With a mono camera, if I don't have the correct color filters with me at the time of exposure, it's very difficult to adjust tones in post. The primary tool for doing that is dodging and burning. Sometimes that works just fine, but more often than not there can be unnatural artifacts -- things like tree tops and/or mountain peaks ending up looking artificially manipulated and unnaturally darkened when trying to burn in the sky, even for people with very good dodging and burning skills. OTOH, If I'm using a color camera I can very easily fine tune the b&w value of the sky in post simply by adjusting the blue channel. 'Not as much control as a good set of filters, but a very convenient and typically very satisfying alternative.
This frees me up to pack my camera bag without having to worry about carrying a bunch of filters. If I weren't so lazy, I might have gone the other route.
For anyone who is interested, all the b&w in my gallery were done with color cameras.
You are the pro and I should listen. Should. But I have an old M8 that is great in mono. The M9 and M240, too, but the M8 seems a bit more authentic. I shoot both RAW and JPG but use just JPG. I am just about as lazy as a man can be without an iron lung to breathe for him so JPG is great.
I understand I can go through the RAW > mono conversion but for my amateur eyes I do not see the advantage over letting the camera do it. And, also, I am not out there competing to sell images so can be way more relaxed. Oh, wait, Pixii shoots RAW mono. It is often good. I have not shot PIxii in a long while. I'll have to find it, upgrade the software and shoot some RAW mono to see. You always find work for me. ;o)
If you're not trying to alter your tones from what the camera gives you SOOC as either JPG or raw, there's probably no advantage to be gained for you to do raw to mono conversions or change the way you're shooting or processing (if any). Camera generated jpg can be terrific looking IF you hit exposure and color balance just right. The problem with JPGs is that so much info has been thrown away to get the file size down, that those files are much less malleable than RAW. So if you do decide to change things, the results will start looking obvious and usually not so good much sooner than with a raw file.
What I'm discussing likely has the most application for people who want to alter their camera default tones in order to achieve a different artistic perception.
Think about Ansel Adams famous Half Dome photo with the drastically dark sky. You could not achieve those dark sky tones with your SOOC approach unless you used filters or changed things in post processing. Adams used a deep red filter when making his b&w negative to get the sky to go so dark. That same approach would be necessary on a mono camera in order to get similar results. But with a color camera, similar effects can be achieved in post by manipulating the blue color.
Here's one where the sky was too light in person. I wanted it darker but not as dark as Adam's famous photo. If I had taken this with a mono camera and didn't have red or other sky altering filter with me at the time of exposure, I'd have a very hard time darkening the sky like this because I'd have to burn it in. It could be done here because the interface between land and sky is pretty simple. But where it is more complex, like with bigger trees and/or jagged rocks or mountain peaks, it can get drastically more difficult to burn in the sky and have it appear natural and not obvious without artifically darkening the tops of the trees or mountains or whatever is interfacing with the sky.
L1007920 by Brusby, on Flickr
All approaches are valid, and I think after all these years of having tools available, many know what they prefer and why.
I have converted many colour images, and they turned out great. Manipulating the blue channel is, of course, equivalent to using red and yellow filters in black and white, but I often encounter artefacts when doing so in colour images. Additionally, white balance plays a role here as well. My most problematic example is the DP2 Merrill. Great tones in b/w, but try to darken the sky...
My film cameras and M Monochrom cameras had yellow and orange filters essentially glued to them, and the results were 90% there. In addition, I shot a lot in the snow, and the fine structures and shades in the snow are something b/w film and monochrome cameras seem to capture very well. A high-resolution colour camera and lens would likely do the job fine (the GR3x is pretty darn good I must say), but for what I do, I prefer compact cameras - and here, the options are limited.
Think about Ansel Adams famous Half Dome photo with the drastically dark sky. You could not achieve those dark sky tones with your SOOC approach unless you used filters or changed things in post processing. Adams used a deep red filter on his b&w negative to get the sky to go so dark. That same approach would be necessary on a mono camera in order to get similar results. But with a color camera, similar effects can be achieved in post by manipulating the blue color.
Fie, fie on you with talk of dodge and burn. LOL Of course you are right. And you strive for a higher artistic result than I, and get it. I am just a street/documentary shooter which translates to stuff around town that interests me. Maybe no one else. For me they are aides memoires.
My favorite photo of all is the head baker in his retail doorway and it always takes me back to the moment. He is saying to himself, "Another Gringo. They all come, take pictures and promise me some. I never get the pictures. Same story again." We went back a couple of months later with a scad of 4 x 6's and some 8 x 11's laminated in plastic. I cautioned him to keep them out of the light and he told me not to worry. He was taking them home with him that night. I was the first to show up with photos for him. So I am the primary intended audience and it works for me. That the baker could look at them and enjoy photos of his business and remember that some Gringos keep their word is great. It made him happy; he had been really kind to Bob and me when we were there. So often for me the camera introduces me to people and places that interest me that I would not otherwise go. Any way you slice it, it is a thing I enjoy.
I am pretty shy but mask it. I would not otherwise hang around the harbor, some of the neighborhoods or Logan's Tuesday Night Pinball League. I have to go again. The camera is sort of a passport for me. And I can enjoy the events again and again.
As for JPG's. that HB cranks out gorgeous JPG's with their HNCS. I am amazed at the quality of the JPG's from the camera. Just this recent shot to Spicy Tofu, not well framed and in bad light but the colors are just great. I should have taken more time but that tofu dish was calling my name and I was hungry. It's a good JPG.
B0002759 by West Phalia, on Flickr
I just don't understand why so many people seem to have such an aversion to editing images. In all but the rarest of circumstances the camera doesn't "see" like we humans do. So most SOOC images usually differ from what we perceived, often drastically.
I'm not suggesting anyone needs to do it my way or should change their preferred way of doing things. If it gives you pleasure, I suppose that's all that matters. More power to you.
It's just that I don't get it, when it's so easy to make huge improvements often with the most minor of tweaks.
You are absolutely right, again. I did on location recordings for years as a hobby. When I started I thought that "no edits" would give me the pure sound. Well, yes and no. I found that I could account for room acoustics, never really good, and perhaps tonal unevenness and so on and wind up with a better product. It took years of practice and a super audio editor with super plug-ins. Sound familiar? Yes, and I think that the audio observation that of you can hear the editing it is too much applies also to photo editing. You gotta be careful or you can wind up with post cards.
But, and this is so important, my recorders did not "edit" the recordings the way that cameras edit images. And current AI and good color profiles make good images almost a given. I like a good lens on an M240. I have Phocus of HB but other than possible future HEIC manipulation I do no think I will be doing much editing. But you just never know.
Could you please send me your leftovers?
(What was this?)
(What was this?)
This is what is called on the menu "Szechuan Style Crispy Tofu 香辣豆腐" The Chinese characters translate to "Spicy Tofu." The wife of the couple who own the place and who waits table suggested it to me. It is simply tofu, coated with some what I think is a dry batter of probably con starch and some spice, it is deep fried and served up with the green beans, scallions, red peppers and peanuts. It tastes better than it looks and has steered me off many other dishes. The restaurant is an anomaly. It is first class tucked into a small mall in a down-at-the-heel seaside community. Go Figure. I have been to HK and PRC and lived in the SF Bay Area for 20 years. These guys are playing in that league. And they are really nice folks. Dinner Menu | New Garden Asian Cuisine
Yes, thev have two kids, a boy and a girl. Yes, they both get good grades. Mom told me, "They have no choice." ;o) It's the old immigrant story. Just great folks.
You can also use RAW processors that skips the demosaicing of a color sensor and goes straight to monochrome. That eliminates the potential sharpness increase of a monochrome sensor.
Iridient Developer just shipped v5 with a bunch of new raw processing options to go directly to monochrome without demosaicing the data first.
Interesting - many thanks for the heads up! It seems to outperform Capture One in fine details even in colour.
Is there a reference to no demosaicing in this mode (and other settings needed to avoid demosaicing)?
In Iridient it has a monochrome tab which is where you convert to monochrome using the color data in the file. This is a more traditional conversion after demosaicing the data.
In the Detail tab you can select different raw process modes which literally change how the program demosaics (or not). The help file doesn't straight out say the mono isn't demosaicing but it hints that this is the case. From the manual:
"There are several special monochrome RAW conversions available as well. These can be both faster than their color counterparts and will tend to have a slightly different "character" than using color RAW processing with monochrome conversion which can quite a bit depending on the various methods used for the monochrome conversion (Channel Mixer, LAB Lightness, etc). With direct monochrome RAW processing you do lose the ability to use the sensor's color information for example with the Channel Mixer or other RGB monochrome conversion methods like Desaturate."
To double check this I emailed Brian the developer of Iridient:
1) Do the RAW Process monochrome conversion avoid the demosaicing to color and then converting to B&W? From the help file it sounds like these are a more direct conversion.
"Yes.
The RGB based (post demosaic) monochrome conversion options on the "Mono" panel, particularly the RAW Channel Mixer v3 options, also give excellent results and provide more flexibility in blending options such as to mimic traditional monochrome color filters.
With very high resolution, modern sensors such as in the fp L you may prefer the additional creative flexibility of the RGB based monochrome conversions over the slight gains in quality from the monochrome direct conversion.
If you are looking for a neutral monochrome conversion much like a monochrome sensor would produce then the monochrome RAW processes on the "Detail" panel can give slight advantages in fine detail, noise and dynamic range."
Brian has also said the:
"Iridient Transformer application upgrades with these new Bayer RAW processing methods will be released over the next few weeks. My goal is to have all 5 Transformers updated by the end of September."
Transformer is a quicker processor to go from raw to DNG with Iridient's raw processors. Those programs are cross platform so this will bring these options to Windows machines that can't run the full Iridient Developer.
This site compared a color camera vs monochrome converted sensors to see what kind of resolution gain there is. He found about 25% gain in lp/mm. I've asked if he ever compared against a color sensor going straight to monochrome (no demosaicing) and he hasn't done that yet. Hopefully sometime though as it would be interesting to see the difference there too.
Hope this helps,
Shawn
Meant to post this awhile ago but Brian has updated all the Iridient Transformer apps (Canon, Nikon, Olympus, Sony, Fuji) to the latest version of his RAW processing and for Bayer sensor cameras that includes the new versions of the direct monochrome conversions which avoid demosaicing the file. Transformer is basically a batch processor that takes RAW files and uses Iridient processing to give you linear DNGs (or JPEG XLs) that you can then edit in your chosen program. Currently on sale for $36 and the license is cross platform for Windows and Mac.
The Fuji version of Transformer gives you the monochrome options for Bayer sensors (GFX series) but not X-Trans sensors. Don't know if that is a temporary thing or not.
Iridient Developer gives the older direct monochrome options for X-Trans but not the new versions he just released. Iridient Developer is a full editing program that supports many more cameras but is Mac only.
Is there a good direct monochrome tool for iOS or iPadOS? I often need to work with a mobile device.
Not that I know of but I really haven't looked. I do all my raw processing on my macbook.
Thanks, I can’t take a laptop a lot of the locations where I work (I think the venues are concerned about recording and/or hacking the sound system) - my info from them says directly that I can bring a mobile device but not a laptop.
There are several image processing apps I can use on my iPad Pro 11", but just for example I downloaded this raw photo of my '64 Nikon F, made with the Leica M10-R, and rendered it to B&W using SnapSeed in about a half a minute:
Nikon F plain prism, 1963-64 vintage
Leica M10-R, raw capture
Processed with SnapSeed on iPad Pro 11"
You can do similarly with Photomator and other apps. 🙂
G
