W
wlewisiii
Guest
cmedin said:I will take a considerable look at the Canons. Compared to the II/III series Leicas how do the Canons shape up prons/cons? Sorry for all the questions, but you guys are an excellent resource and this is one area of camera gear that I am very clueless in.
There are a number of smaller detail differences between the Leica II/III & the Canon III/IV series of cameras, but the important differences are in the viewfinders. Canon's major innovations were to use a combined VF/RF and to have multiple magnifications. There is a lever under the rewind knob that is marked F, 1x, & 1.5x. The F position gives a 50mm FOV with an accuracy sufficent for a slower lens like the 50/2 or 50/1.9 collapsibles. The 1:1 1x position gives the FOV of a 100mm lens (which is very usable for a 90mm lens as well) and is more accurate in focusing. The 1.5x gives the greatest accuracy in focusing and is very useful for larger aperture lenses (the 50/1.5 springs to mind) and gives a FOV appropriate for the 135mm lens. Anything wider than 50 will require an accessory VF but that shouldn't be an issue based on your earlier preferences. A Leica II/III by contrast requires an external VF for anything other than a 50mm lens and has a separate higher magnification RF window and the 50mm FOV VF window.
I really need to save the pennies for another IVSb - I had one and regret selling it. I found it much nicer in use than the one Leica III I've had a chance to use. Build quality seemed just about the same to me.
Peter Dechert, who has his own forum here, is pretty much the Canon RF guru. A question or two over in his forum might be useful for you.
In the end, I'd recommend the IVSb with a nice chrome Canon 50/1.8 or 50/1.5 lens. When you do want to go longer, the Canon 100/3.5 is another lens that works very well with this camera. But then again, I am a Canonista...
William
