Leitz 5cm finder SOOBI question
N
Nikon Bob
Guest
I have a Leitz 5cm finder that has the bright lines cocked. Has anyone taken one apart to adjust the lens that has the bright lines to get them level. Usually there is a retaining ring but I can't seem to see one. Thanks.
Bob
Hi Bob,
There's a small screw in the bottom, and if you loosen it you can rotate it until it's correct.
Mike
Stu W said:
I think Leica's designation is SBOOI not that it really matters. Stu
Yup, 100% correct Stu. Sometimes I type too fast and don't check.
Mike
Thanks for the info, I didn't want to do anything until I had some idea from somebody that has done it.
Jim
I think you are right also about the back unscrewing so that will come in handy should it need an internal clean.
Bob
Mike gave you the right way.
A very small screw is underneath. If unscrewed, you may pull the optical part to the back and then turn it until it's right level, push it inside again and screw tight again.
I did put the optical part away (which is inside a second metal cylinder) to have the SBOOI body chromed.
