Lens detection in m8/m9
ziengler
8:03 PM
Hi guys, just to check is there a menu to show lens info for 6 bit coded Leica lens for m8 and m9? (etc.. 50mm 35mm ...)
like for example I plug in a summicron apsh 6 bit , is there any feature in the menu that will assure me that the sensor are still alive and is able to detect the lens?
For M9: If the lens-detection in the main-menu is switched on, and you have attached a coded lens, you can press the Info-Button. The last line on the screen shows, what the camera has detected. This is described in the manual also...
hmm I though of seeing the info on one of the m8 also, think I have seen wrongly
possibly a m9
The menu for manual lens selection on the M9 will not show you which lens is actually mounted if you are in manual selection, it is for selecting a lens without 6-bit coding.
If you want to check which len s the camera h as recorded in EXIF, go to playback and push the info button, both on the M8 an d M9
