wolves3012
I've recently acquired a Zork 2C, which arrived a few days ago. Bought off the bay, the seller wasn't entirely honest although she appears not to sell cameras usually, so I'll forgive what could be inexperience. The "smooth focussing" turned out to not so smooth and what little lubricant there was was very dried up. Easily sorted. The "works properly on all speeds" turned out to mean that it did fire, sort of. The second curtain release was all gummed up so it only "fired" on releasing the button. Easily sorted. First curtain tension was so low that only the second curtain colliding with it caused it to open. Easily sorted. Self-timer didn't release the shutter, though it did unwind. Small spring dislodged, sorted. A thorough lubing has it all running smoothly & reliably now.
Ok, enough of the ramble...I think the lens has fungus but since I've never seen it before I don't actually know what I'm looking at. There are some very fine, almost-clear, spidery threads visible with a 10x eye-glass. They appear to be on the back of the front element and somewhere probably on the front of the second. There isn't a great deal of it, but is this fungus?
Assuming it is, what's the likelihood of being able to remove it and what's the chances there's permanent damage? I have other lenses I can use so I'm not going to cry if it's not fixable but I'd rather keep the lens available since it seems to be the original.
I think the camera has been kept in a loft or something, since there's evidence of dampness inside it. There was some furry corrosion of the alloy in places, which I've cleaned off. Presumably good conditions for fungus?
The other bit of help I could do with is how to strip the lens fully, I can't seem to find anything on the rigid I-50. I'm sure someone on here will point me to where I should have found it - I have looked, honest!
