Lens Hood for Yashica-A?
bgetty
Brandon Getty
11:16 PM
Hey folks,
I just picked up a very clean, very functional Yashica-A from fellow RFF'er Jack Conrad. First entry into medium format and TLRs! My first roll turned out well, but I do notice a bit of flare in sunnier shots. I've read that hoods of the 32mm push-on sort will work. Should they be square, like this one:
http://www.ebay.com/itm/32mm-push-f...y_VintagePhotoAccessories&hash=item564e603f55
...or can they be circular, like this one:
http://www.ebay.com/itm/32mm-push-f...968?pt=LH_DefaultDomain_0&hash=item35c0f97688
I just don't want the hood to obstruct the viewing lens or show up as vignetting in any frames. Any input is appreciated! Thanks a ton guys.
The round hoods are for TLRs with geared focussing (or really any camera with a rotating lens barrel I guess) - so as the hood rotated with the lens it does not cut into the corners of the image. It should not cause any problems on the Yashica A, but I would prefer a square hood because it provides better shading.
