Lens selection and shutter noise.......
phototone
8:50 PM
Van Buren, Arkansas USA
This is not a friviolous concept. Try it out. The heftier the lens, the quieter the shutter sound is. The extra mass of the lens absorbs some of the shutter sound.
Mount a big old Nokton, or Summilux or something and check out the shutter sound, and then mount an itsy bitsy Elmar or something similar and check out the sound.
Also, the shutter sounds will be quieter if the camera is put into a half-case.
Okay, I'll bite. 🙂
Just tried it out on the Pentax. I first tried it with several air shots with the "flamethrower" 28-135 zoom mounted with my eyes shut to get a reference level.
Then with the normal 50 f2 mounted. Significantly louder at close range.
Now with the body only, no lens ... OUCH! Significantly louder.
I must admit I never thought of this. Hmmmmm ...
You're all sure you aren't confusing this with how you hold the camera, aren't you?
I mean, a 28-135 will be cradled in your hand, something you'll not do easily with a pancake lens..
backalley photo said:
i'd be curious to hear what the difference was with a spl meter used.
joe
Now, Joe, never let the facts get in the way of a good story! Subjectivity rules ok!
Anyway, another good attribute of those heavy Canon 50/1.8 lenses!
For my very unscientific test last night, I had the camera in my lap pointing it toward me so I could hear what a subject might hear. Ditto with the normal lens. There was a significant difference in the intensity of the >>THWAP<< sound. I can see how the mass of the lens (which is probably as much as the body if not more) absorbs the noise of the shutter, although I've never really thought of this before.
