sanmich
I think that's a very good idea.
Maybe a subforum?
Maybe a subforum?
1. Don't Dream, Practice
Stop pitying yourself for the lack of time, beautiful subjects, wonderful sceneries, 'happenings'. Anything in the world can become your subject including those readily accessible to you. A subject looks mundane only when the photographer didn't want to spend the time or the effort to make it look otherwise.
2. Aim higher
If you decided that you want to use your cat as a subject, don't be satisfied with just taking snapshots of your cat. Do your homework, look for cat photos that engages you. Don't copy, synthesize, create your own version.
Obviously, substitute 'cat' with anything you like to use as a subject.
3. Don't bore you viewers
Before you post multiple pages of your 'work', stop and think, what are you trying to convey?
This simple question is what distinguishes posts like those of Chris Crawford's and some threads about using one of the most expensive camera in the world by showing *lots* of shots that cannot be distinguished from those shot using a P&S.
Again, not because the poster is not a good photographer, just need a little friendly nudge to kick him/her into higher gear.
2. Aim higher
It's a good idea Joe, but anything that's posted along these lines simply gets subsumed by all the new posts landing on top.
A couple of years back I posted an extended and illustrated essay on Art History, Composition and Colour Theory, it was well received at the time, mostly, but was gone from the home-page in a few hours and the forum-page in a few days ... it's hardly worth putting the effort in to write it that being the case.
This makes the assumption that you can psych yourself into photographing subjects you find boring. Maybe you can -- but why would you bother? Caring about the subject is normally an integral part of taking good pictures.
What you said. But step 0 should be
0. what are you trying to convey?
Do you still have the essay ? Would love to read it !
Cheers
Steven
Can I kick this off with a real elementary example?
Lynn (lynnb) left a comment about one of my gallery photos - he said it was overexposed:
I exposed for the shadows, and the sun was really strong that day - I was not sure how to best handle it. Exposure was (I think) f4 @ 1/250 (Tri-X)
Would could I do to improve that? Stop the lens down more? Change development strategy? (I developed in Rodinal according to the chart.)
UPDATE: I've had additional criticism that I was too far away. Who says that the RFF forum is all sweetness and light!? ("Good capture!") That remark stings - I am well aware that I do not get close enough, and using the 21mm lens at the march only made that worse.
Randy
Dear Will,Interesting assumption, Roger.
Although I suggested nothing of that sort.
I think we can grow to care about certain subjects that are accessible to us, that we ignored in the past because we haven't looked hard enough.
Which is far better than making excuses because one does not have access to the immediately photogenic subjects or scenes.
Randy,
In high contrast light like that, you can reduce contrast by shortening the developing time. The developing times manufacturers recommend are for normal brightness ranges, basically what you get in light that is soft, like in overcast conditions. When the sun casts dark shadows, the range of brightness in the scene is too much for the film to handle when developed to normal contrast.
Try reducing the developing time 30% from normal. You will need to increase exposure one stop when you do this because the film's effective speed drops about a stop from such shortening of the developing time. So, determine correct shadow exposure, increase it a stop, then shoot and drop the developing time 30%.
These are two examples of this. Film was 120 size Tmax 100, developed in Rodinal for 30% less than normal with one stop more exposure than normal.
Randy
In the photograph of the protest, the photographer is photographing from the sidelines. There is not enough engagement with the subject to make the photograph memorable.
Here is an example of an image that was effectively ignored. I was driving through South Texas and was heartbroken at the condition of the rangeland in this particular area. I stopped and took this image. I only had a 50mm focal length and couldn't get everything in the frame I wanted, so I took two frames and later stitched them together in CS4.
I suspect I may have been better off depicting the dry conditions with several seperate images in a series. They could have shown more detail. #1 I didn't think of that at the time. #2 I didn't have access to the private property. ( I was shooting over a fence) #3 I was traveling on business, and couldn't devote time for more invloved reportage. That's my story - what do you say?
Your opinion... But it can be questionable... If true, no memorable photographs would exist done with 50mm lenses... (And above...)
Photographs are memorable not because of engagement with the subject, but because of content, no matter where the photographer shoots from.
Again, you can "be there" with a 28 or 25 and get boring photographs.
About improvement: I found interesting a good photographer once said he didn't use to look through camera too much: almost never... Just for an instant: while shooting... I find looking at reality without camera, means a lot more than I used to think...
Juan
2. Aim higher
