Light Leak or...
1750Shooter
11:26 PM
Portland, OR
Testing a new camera & this showed up on every photo in the 1st roll. Sorry, won't upload - photos show a vertical bar about 1/3 in from left side. It's in the same place & same size on all photos. Camera shop said they thought the shutter was "dragging", but since pictures were exposed correctly, I'm thinking a light leak. Any thoughts or suggestions?
If it's consistently in the same place it's most likely mechanical...is the stripe darker or lighter that the rest of the photo...
If it's a light leak the negative will show the stripe through to the edges...if it stays within the image area it is not a light leak...
Try another roll using as many different shutter speeds as possible...see what happens...
