DwF
Yes to histogram particularly shooting with the Leica MM. I do find that once I begin to use and process with Histogram, I become more distracted from whatever I am shooting.
Slows you down? You take one reading on the sunny side of the street and one in the shadows and fire away, until the light shifts a stop or more.
Yes, of course.
How many human eyes - including those of experienced photographers - can detect a one-stop change in light intensity?
Chris
Practice makes perfect. It doesn't take long for your eyes to pick up on that.
A handheld meter is almost a necessity with the Leica M10 (or any other digital M).
The built in metering system is rather basic and can be unpredictable and inconsistent. I found hat using a handheld meter with he M10 and 'learning' the sensor characteristics produced far better results. The built in meter always wants to make everything you point it at middle gray. More often than not this works just fine, but a hand held reading leads to far less overexposures. After a while you start to learn a new set of 'sunny 16 rules for several ISO settings and the results improve dramatically with big gains in highlight retention and shot consistency.
While were on the subject of the M10, so far the worst thing about the camera is the battery life. If you are stalking the streets for hours on end looking for shots you will need 3-5 batteries. Preferably 5 or more. If you put the camera on power save the startup time is just long enough for you to miss a fleeting shot, which is infuriating. The only problem is that the batteries are $200 a piece, which is obscene compared to every other manufacturer. So, after you spent a fortune on your M10 you get to spend another +$1000 on batteries.
Anyone who expects a camera with auto exposure to know what precise proper exposure is for every scene has an
unrealistically high expectation of camera automation systems. Same goes for auto focus systems, for that matter.
I use manual exposure and manual focus almost exclusively, though I have
heard there have been some advances in those areas in the last 30 years. 😉
My brain (i.e. my photographic knowledge + experience) is then
always a deciding factor in the success - or failure - of my photos.
An exposure meter only provides raw data, which of course must be analyzed to be useful.
Chris
One stop, really? I'm pretty doubtful. Sounds like a brag to me. My eyes automatically adjust to brightness and can be easily fooled.
So despite 45 years of "practice" I'll still always defer to the constantly updated readings of my camera's built-in exposure meter...
Chris
I don't find using a hand-held meter to be "essential" to getting good exposure with any Leica M digital. The Leica M digital cameras's meters are perfectly predictable and work very accurately, assuming you have learned the metering pattern, where to point the camera to take a reading, and know how to interpret that reading. It's pretty much the same as using a hand-held meter, modulo the option of incident reading.
I also don't find it much slower to use a hand-held meter than to use the in-camera meter if I'm trying to achieve critical, proper exposure. Both require understanding, skill, and practice to get the best results. Same for using the histogram or display brightness on a Live View camera.
I wouldn't say that I can see a one stop difference in exposure needs easily. However, with experience, I know when I'm looking at a scene when I need to adjust by one stop, a half a stop, a third of a stop, etc. Same for film (B&W, color neg, color slide) or digital capture.
Anyone who expects a camera with auto exposure to know what precise proper exposure is for every scene has an unrealistically high expectation of camera automation systems. Same goes for auto focus systems, for that matter. 🙂
G
In my experience the M10 meter works fine if you have time to adjust. Like you said you need to decide what in the scene you are going to use as middle gray and go from there. Usually you can nail it with one or two test shots and a look at the histogram.
But the problem comes when you are shooting very quickly on the street, when there is no time to take a test shot and potentially fiddle with the exposure, because the moment will only be there for a few seconds or less.
On a sunny day a white t-shirt that takes up a sufficient area of the frame will throw the meter. Same for dark clothing. It works pretty good on overcast days and for some reason at night, but it will be fooled unless you have the time to adjust. That's where a hand held meter reading makes all the difference.
I do agree that you really can't rely 100% on automatic metering. Even a sophisticated matrix meter will at times get fooled or fail to give you what you intended.
