Doktorkay
Echoing some other comments:
-Nikon S2 or S3, and SC 5cm f/1.4
-Contax IIa (plus a CLA, they always need work), and 50mm Sonnar, or 35mm post war Biogon/Planar. You could start with one of the inexpensive Kiev copies and see how you like it.
-Later Canon LTM cameras
-Bessa R plus a lens
-Yasuhara T981 plus a lens
Watch what comes in at Kamarastore, the Finnish used shop. They often have cameras like these, much closer to home than buying from Japan.
I'll definitely take a look at it!
But maybe you shouldn't write off fixed lens RF's. There are tons of options, some of them have great lenses, and the benefit of a simpler construction and more minimal viewfinder. A lot of them have some form of metering and a mechanical shutter. What focal length do you like using? That will tell a lot about what camera you should wind up with anyway.
I'm not considering fixed lens cameras because I would like to have a single camera with multiple lenses, because I often use 28/35 or 40/50.
Otherwise I would have already considered the Canonet QL17 GIII
