Noserider
Christiaan Phleger
I'll forward my coffee fueled opinion and state that you should go with your mentioned thoughts and at least try the Nikon F3 route. If you want to alter the lens mix from more classical Nikon MF (which could be just fine depending on your tastes and needs) you could use the F3 with Zeiss ZF.2 primes.
For a Nikkor line up I'd suggest looking at
28 f/2 to start; try the Zeiss f/2 version to compare. Buy the 28mm Otus and call it a day.
At 35mm the choices get interesting. The Nikon 'G' 35 f/1.4 won't work on the F3 but I vastly prefer the very old 35mm f/1.4 N.C Nikkor F. Again; try the Zeiss and you may prefer that to make your ideal 'Cron&Tri-x' style.
For the 50mm I'd start with the 50mm f/1.2 Nikkor, again the very fine AF-S 58mm f/1.4 won't function properly on an F3 (we really really need a pro level film Nikon that can use these new lenses F7 please!). For that fun option the Milivus 50mm looks very interesting and as well the Otus 55mm will be the obvious end of the discussion.
To charm up the F3 consider the natural Titanium F3T or in basic black consider changing out the finder, the smaller finder is still quite doable with glasses and the lower profile and weight savings is apparent. Choose a DA-2 for its way huge finder view and over the top presence but watch out the glass in the finder is so easy to crack with the smallest tap on the brass finder cap. Choose a waist level or mag finder to shoot very stealthily and to be 'different'. You could get all the finders and choose as you desire and don't forget about the G and H screens which are Crazy in low impossible light. Have fun which is part of photography
