Looking for P/UV filters
hogehoge
10:11 AM
Asia
Hi there,
I'm looking for Protection/Ultra Violet filter (46mm) for CONTAX G. Does anyone know where I can buy them at convenient price? Ebay doesn't have so much filters. Also, I've heard that the original CONTAX P filter is mono-coated, not multi-coated. Is this information true? I may buy third-party one if that's true.
Thanks.
hogehoge said:
Hi there,
Thanks.
B+H photo carries the name brands, new (like B+W, Hoya HMC, etc.)
You can also get cheaper 46mm Quantaray MC filters from Ritz Camera / Wolf, typically.
Roland.
Hoya has merged with Pentax, apparently, and I see they're now using the SMC "Super Multi-Coated" terminology on some filters for a slightly higher price than their regular HMC "Hoya multi-coated" ones. Just ordered one of those in 77mm size, plus B+W Haze(UV) MRC "Multi-Resistant Coating" in 58mm and 82mm sizes. Price of that 82mm in the "slim" version was $125... ouch! Be fortunate you're only after 46mm! 🙂
The 46mm Contax filters made for the G system are often available from KEH or Adorama. The UV (L39) is usually the most expensive and the cooling filter (B2 = 82A) the cheapest. There is also a 1A skylight, A2/81B warming filter and P (clear glass). According to the brochure, the P filter is single-coated on front and back, and the other filters are multi-coated.
The main "feature" of these filters is the finish, which matches the lens. Otherwise they are not obviously superior to other brands, and the filter mount is a bit thicker than many others. I like the Nikon 46mm NC (neutral color) filters that are often available as new old stock on ebay, they have nice coating and thinner mounts than most brands.
Thanks all.
After submitting this thread, I finally found the store selling brand new CONTAX P filters. I ordered them.
