LTM to M lens adapter.
fidget
Lemon magnet
9:26 AM
Northern England
I have a few LTM lenses that I would like to use on an M mount camera (R2). I have ordered a couple of adapter rings for this. Is there anything to be aware of about these rings? What is the nominal thickness of the ring, if this is the critical dimension?
regards, Dave............
You should probably stick to CV or Leica adapter rings. I've heard that the cheap ones from China are poorly machined.
You also need to ensure that you get the correct ring for the lens. Cameraquest is a good place to get them.
