brothernature
Are there any m-mount film cameras that sync at all speeds?
None that I know of. Certainly none made by Leica.Are there any m-mount film cameras that sync at all speeds?
Before you jump in, be aware that:Hmmm I have a bunch of bulbs (somewhere) and the CEYOO is cheap.
rangefinderforum.com
I wonder if the folks who made this stuff would think we (collectively) - still discussing this stuff in the first-quarter of the 21st century - need to get a life. 🤣If it only goes up to 1/200 it’s a bit of a waste of a Compur! Most went up to 1/400 or 1/500. A Prontor would have done fine, and on the whole, they stand the test of time better. I have seen a lot more stuck Compurs than Prontors.
Though I don't suppose they were thinking 50+ years into the future 😂
At least one of the leaf shutter lenses was built by Leica. I often think they put crazy things like this together so people like us _will_ talk about them. They are expert at building the myth.I wonder if the folks who made this stuff would think we (collectively) - still discussing this stuff in the first-quarter of the 21st century- need to get a life. 🤣
While generally true information, there's more to add to this story for full understanding....
Electronic flash is instantaneous and usually focal plane shutters can only take advantage of it at the speeds where the shutter is fully open, so it's rare to get anything which will sync at anything higher than 1/250 (and even that's rare). But flash bulbs? They can have very long burn times, comparatively.
If you look at an M2 or M3, they both have two flash ports. One of them is for bulbs, and will sync at all speeds if you have the right bulbs. Here's a link to the manual (well, pamphlet) explaining what you can use: https://ia804603.us.archive.org/16/items/leica-flash-guide-numbers_202112/Leica Flash Guide Numbers_text.pdf
With an M2 or M3, a CEYOO flash, and some M5, #6 or #26 "flat peak" or FP-class bulbs, you can use any shutter speed you want. As an extra special bonus, you'll also get a lot more light than you do with the average electronic flash. And you get to blind your friends! It's win/win/win.
Glad I limited my comments to Leica M bodies ... I have little experience with Hexar RF or the modern Cosina Bessa models. 😉Hexar RF and Bessas and the Zeiss ZM have vertical shutter travel and sync at 1/125. Not all that fast but faster than the horizontal travel M bodies. 🙂
I presume you mean the modern Zeiss Ikon ZM...? A friend of mine had/has one of those.The Zeiss is electronic, would have to look up the others.
Or a Hasselblad 500CM ... then you get interchangeable lenses too. 😉Buy a nice TLR. Not only does flash sync at all speeds but you can see the flash effect through on the fresnel screen.
