My beater M3 is giving me a dark stripe on the RH side.....seems to be there at different speeds with varying degrees of severity. Comments appreciated...
Thanks,
Mike
Basically, the shutter curtains are not opening and closing at the right speed in relation to each other - most likely, the second curtain is closing too quickly which is underexposing the area where you're seeing the banding.
The camera needs a CLA. There are 2 possible faults. The first is that the curtains are moving at different speeds and the other is a problem caused by the shutter brake. This causes the first shutter to stop before full travel and then complete the travel once the second shutter catchs up.
Adjusting that is a non-invasive procedure and any proper camera repair tech should be able to fix it- sending it off to a Leica specialist if nothing else is wrong may be overkill. You may want to call around locally first before boxing it up with the peanuts.
I know Ontario is a big place, but if you're relatively close to Kindermann Canada, take it there. They used to be a Canadian distributer/service centre for Leica and their service guy Jerry is factory trained.
E_mail me I wlll send you step how to fix it. It called bouncing, the second shutter curtain brake need to be adjust. But if you also have other problem, just send for CLA.
