M4-P With Loose Bottom Plate Latch
Joe Jesus
shaggy nurse
8:45 AM
Fort Wayne, IN
Took delivery of a very clean M4-P today. Problem is, the little key that one turns to release the baseplate doesn't stay in it's spot when the plate is latched on. Is there an easy fix for this? I'd really rather not have to roll around with a bit of tape on the bottom of my camera.
Thanks.
Thanks.
I had the same issue with an M3. Basically the issue is the pin that holds the latch together, and it needs to be replaced. It's an easy enough task to do, the issue is what to replace the pin with...I took mine to a professional to handle, no idea what he used but he fixed it!
