bo_lorentzen
M on motorbikes is not a problem, wrap in a couple layers of fleeze or better.
I made a little sleve of hard foam, then lined it with half inch very soft foam.. taped it all together with black gaff-tape on the outside. camera with 35mm snug as a bug. but have been known to simply stuff the stuff in a extra thick hiking sock.
vibration is very real, had a tripod come completely undone in the case on the back after a 10 hour ride.
The tank is a good spot for cameras, its in the center of the bike which reduces the biggest shocks a little. use foam, keep the camera insulated from vibrations..!
I took several around the USA on the bike, everything worked just fine after 12.000 miles.
The picture of the padded M tank case seems like a perfect solution, but less padding will do. (at least it worked for me)
