bean_counter
Hey, it's a troll. Good times.
You expected something else on a thread entitled "skuttle butt"??
Have fun, it's Friday 😀
physics suggests that when you increase the sensor size, you need to move the lens away from it at least a little in order to help compensate for the steep angle at which light is hitting the edges of the sensor.
[FONT="]FFM9? Is it possible or not? It can’t be done, some posit, sighting ‘the laws of physics’.[/FONT]
[FONT="]O.K. so it can’t be done. [/FONT]
[FONT="]The rumored M9 is supposedly bigger than the M8. Perhaps the new M9 will accommodate legacy m-mount lenses (all existing m-mount lenses) and provide a 1.3 crop image, just like the M8. The NEW (modified) m-mount lens line-up, purposely built for the FFM9 (not legacy compatible), will cause the sensor to reposition itself slightly further back from the mounting flange to resolve the ‘angle of light’ issues.[/FONT]
[FONT="]This resolution to the problem would be a kludge for sure. So if the rumored FFM9 is more than just vaporware, than perhaps they have indeed solved the short register issues.[/FONT]
If Leica has come up with a high ISO performing, no IR/UV filter needed, Full Frame M-rangefinder, it sounds all too good to be true.
They can't change the registration distance--then the new camera would need an entirely new lens line. They have to have solved the light-fall-off problem some new way...I'm very curious to see what Kodak and Leica have cooked up here.
If Leica has come up with a high ISO performing, no IR/UV filter needed, Full Frame M-rangefinder, it sounds all too good to be true. What's the downside this time? - Except for the price.
If it's larger than the M8 there's no way I'm buying it. I'll hold on to my M8 or maybe even grab a second one. But the M8 is fat enough as it is.
There is no way Nikon can - or even wants to- compete with Leica M lenses in the shorter focal lengths.
If they got rid of the silly pop-off bottom plate, there'd be even more.
