V
varjag
Guest
Being inspired by the recent discussion on feel of different age Kievs, last night I dismantled my 1976 4A. It's been working fine, although to my experience sutter release and film advance wasn't as soft as on earlier Kievs, plus the shutter has more noticeable snap. After winding/firing the shutter and observing the gearwork, think I spotted at least three problem zones:
1. The aluminium curtain hold lever (the one engaging with the small tabs in the middle of curtain's edge). Its spring-loaded shoulder which transfers the action from release button is bent insufficiently, resulting in some wiggle space.
2. The winding limb mechanism has that notch and tooth coupling, which engages the shutter cocking at appropriate moment. The tooth is poorly finished, so it results is some grindy action during engagement.
3. The tension/resistance of the upper curtain drum feels a bit excessive.
It is interesting that my initial expectation was poor match and finish of cogwheels, which doesn't seem to be the case: they appear to work fairly smoothly.
As of the shutter sound, the snap comes from lower curtain edges hitting the bottom of the crate. This perhaps can be dampened by a bit of foam (just got some from Aki Asahi), though it is interesting to know why older Kievs are more silent.. any insights?
As to the above mentioned points, am not sure what to do. Fixing (1) and (2) looks easy if i can get to the parts, which implies taking apart the shutter assembly. Anyone here ever done that on Kiev or Contax shutters? Would appreciate any hints, ideas and warnings.
Regarding the (3), am not certain if it's a good idea to fiddle there. May changing the tension of the spring affect shutter speeds (which are reasonably accurate at the moment)?
