Mamiya 7ii Light leak help please
robsturcke
11:52 PM
I can't decide if it's the body or the lens. I have had occasional light leaks with my 80mm very rare though. But on my 43mm I get light leaks on the bottoms of my photos, sometimes leaking into other negatives.
http://yfrog.com/kknkbddj
Is there just a problem with the 43 glass distorting the light due to stiff focusing ring/facing direct light source?
Or
Is it the body, and light is leaking somehow through the double channel or soft padded light chamber is damaged?
-Please note I had a fixer problem with this negative so ignore the clearly screwed up center. I have the leak on other negatives, but this is the best example.
