Mamiya 7ii meter and underexposure...a real science!
loic.sans
French expat in London...
11:20 PM
London
Hi there,
I just bought and recieved a used Mamiya 7ii with a 80 mm lens.
This kit is in pristine condition.
SO I have loaded the beast with Provia 400 and ran a test roll.
I just got my film back and absolutely all the frames are underexposed by 2 stops or 3 stops.
So I got out my Leica M7 with the 35 summicron which I consider to be really accurate in 95% occasions. I have placed a book cover in front of me that covers 18% grey and compared both values given by the Mamiya and the leica.
The mamiya gives really weird values, it's always between 1 or 3 stops underexposed compared with the Leica. Also moving around gives me some funny values which tells me that the meter is not center weighted but more like a spot meter below to the right of the rangefinder patch...I am not even 100% sure of this yet.
I'll get my light meter out tonight and will try on typical "no problem for exposure shot".
Is it normal or should I find a mamiya repair center and send the body for adjustment?
Does anyone has any problem with this as well or anyone with tips would be really appreciated.
Thanks for reading
Loic
Yes you're right. THe difficulty is to figure out what exactly this cell is looking it in the frame???
And no there's nothing obstructing the window, and if it was I believe It would be over exposed, my camera is more on the under exposure side.
I am thinking of that, but it is such an unusual thing to happen to a camera like this. If it was the rangefinder out of focus, It would seem normal. I bare in mind that this was my first ever roll with this camera, but yeah such underexposed slide never happened to me.
In case I need to send it for repair...What is the nearest Mamiya repair center in London, UK?
A couple of years back I bought a 2nd hand Mamiya 7 & had a similar problem. It had been sold to me described as being in excellent condition. When i complained to the seller he admitted that he hadn't used it for a couple of years but it had never given problems before. He apparently did some research & came back to me saying that it was a common problem & easily fixed. He offered me $100 to cover this but I was annoyed at having been misled; when I buy something described as excellent I'm not impressed by having to ge it serviced within a week, luckily I got him to accept it back & refund my money. Sounds like you're in a similar position, so hopefully it is a simple service matter, certainly doesn't sound like a meter position or shape issue.
The Mamiya 7/7II is indeed a bit more like a "spot" than center-weighted, and is not TTL.
it is all relative to the FOV of the lens being used... if using the 43 the metered area is probably closer to a spot meter, with the 80mm probably closer to center-weighted and with teh 150 it probably behaves like a matrix...
like any camera/meter, the user has to learn how it behaves.. as long as it behaves consistently then the user can adjust/compensate...
Thanks for the answers.
Double Negative: How do you use the meter on your mamiya? Do you point to an average tone and use it as a spot meter or as a center weighted meter?
250swb: the battery is a premium brand battery, new, so I don't think the problem comes from there.
I am starting to think that the problem might be corrected from good metering practice with this camera. I don't think a meter can go completely nuts like that!
I recently acquired the M7ii (with the 80mm lens) and the first few roles were metered correctly. As I understand it, the longer the focal length the more the M7ii meter becomes a spot meter.
Mine exposes very consistently, although I shoot mono. Mine meters from a very small area right where the focus patch is. I use it in AEL mode in mono and lock off a meter reading from the value I want at Z5 (pavement/concrete/grass etc) and I get amazingly consistent exposures. I found it fine in colour too, though I had to think a bit more and took more time to ensure I got things right.
Using Fuji 400x I would rate it at 320 for great exposures. Sounds like yours has a problem bec FWIW all my metered leicas measure the same and all are 1/2 stop more optimistic than my Mamiya i.e the Mamiya gives more exposure than the Leicas. I use the internal metering on mine with most 400 films rated at 320 or 400 depending on lighting. In the Leica I rate 250 normally.
Hi all,
In fact after a few tests, I can say that the meter underexposed by 1 stop...
In fact to get the correct exposure I need to set the film speed at 200 for a film of 400.
It's ok but a bit annoying.
Has anyone experienced such a problem with a Mamiya 7?
Cheers
Loic
The same way I meter most things; I find an area of the scene (or around me) that is relatively "average" and read that (knowing that meters can be fooled by overly bright/dim areas). So basically I'm taking an "18% grey" reading.
Thanks anyway, my meter is no doubt faulty. However setting a 400 film to 200 on the dial, I get perfect exposure, I guess i'll just send it for repair, as
it is quite unreliable.
See page 11 of the Mamiya 7 sales brochure http://www.mamiya.com/assets/pdfs/M7II/M7II_Brochure_English.pdf for an example of just how center weighted the metering is. (Sorry, I am too lazy to figure out how to cut and paste that particular graph)
I will say mine gives consistently accurate readings. But I do shoot manual after an independent ambient reading while shooting chrome.
Most importantly, I always look at the meter reading when using AE and see if it makes sense. I never rely on the meter blindly.
I've had about 10 rolls through my 7ii since acquiring it a short time ago. I have used the 65, 80 and 150 lenses. I relied on the camera's metering system. I've had correctly exposed rolls of Provia 400X, XP2, and Fuji Acros 100 in a variety of lighting conditions - some straightforward, some more challenging. So on my admittedly limited experience, I'd say that if you're not getting something like that, your camera needs looking at.
You haven't by any chance accidentally placed the exposure compensation dial on -1ev? I often knock that on mine and it really annoys me. I never use the internal meter, though, just a handheld manual meter.
