Spanik
One of the points to take care of is the lug on the prism that can bend and then it doesn't engage well with the lens. I have one ProTL body where the mirror lock-up broke after a few years. Other than the usual foam seals there isn't much that can go wrong. The lugs for the strap are not easy to find.
Some prisms don't behave as you would expect, the AE on my 645J for instance that doesn't do manual metering but that's normal.
With the more modern ones the rubber coating is often peeling.
