Calzone
Gear Whore #1
Keep the oil tank, keep the oil and get an old Mercedes-Benz, BMW, or Volvo diesel vehicle to burn it in. THOSE are future proof. As long as they get somewhat regular oil changes, they will outlive us all.
Phil Forrest
Phil,
Home heating oil is cheaper than diesel and bypasses paying taxes. An old boss did what you say, and he added some kerosene as an additive to prevent "waxing" in the winter.
The furnace is made by "Crown" and has a Mclaen gun. It also has an unusually high efficientcy of 84.3 and also provides tankless hot water.
Oddly the gas hot water heater is there and goes unused.
The owner generously sent us a spread sheet for her utility bills. Her oil bill is remarkably low. When I looked in the attic I saw that the fiberglass insulation that compresses over the decades had another layer added to restore full rafters.
The windows installed are good ones, and I suspect because the heating bills are so low that highly likely cellulose insulation was likely blown in the walls at some time.
Tom the P.E. who did the home inspection mentioned that the furnace has an unusually high efficiency rating; the fuel tank is bigger than the 300 gallon tank he has in his home; and he says if might be a 400 gallon tank. Bonus is that this 400 gallon tank is nearly full.
BTW some of the Volvo diesels were lemons. I had a friend that was gifted one. Not all diesels are good.
There seems to be a natural gas bottle neck in Westchester due to a lack of pipeline. Tom mentioned that in southern Westchester gas conversions are not possible because of a hold-up in supply. He also mentioned that this might likely be extended to northern Westchester. This might explain why an oil heating system was retained. I have to look into this.
Anyways the heating system came as a bonus surprise. It may be oil, but at least I have a good one with tankless hot water.
Another huge bonus is the 1525 square foot home (small house) has a 200 amp service, and also the two car garage has its own breaker panel.
The owner said that this 1912 house has only had 3 owners and she is the only the third owner. The clear narrow heart pine floors we covered by carpet, which she removed when she bought the house. The floors are like 1912.
The pocket doors that separate the livingroom from the dining room appear to have never been used. The look 1912 original, even the finish.
Now I have a 34 page report of many minor things like cauking, painting, and adding GFI outlets to update things. Stuff like cleaning gutters. So the list is long but pretty much minor handyman stuff.
The only ugly job is that the roof on the garage needs replacement. The bones are good. Happy-happy. Even though this Victorian is 4 bedroom and two full baths, it remains a small house.
The basement upon second viewing has a lined chimney for the oil furnace so only part of the basement will be finished, and part will be a utility room for the heating, hot water, fuel tank, washer/drier.
Having a 20x20 garage as a studio space will be a very valuable space. Christian says I can insulate the roof without getting rid of the exposed beams that lack any trusses. There is one beam that connects and straddles two opposite walls for loading, and Tom pointed out that they seemed to have "sistered" the beams to add strength.
Cal
