Just out of curiosity, since I've never used a digital camera that had neither a back LCD or electronic viewfinder. I currently use an M262 and M9P, so optical rangefinders with back LCD's and I also use an Olympus E-M1 outfit, so both a back LCD and EVF...
Let just skip over there being no way to review an image after capture, which I don't understand, but it is, what it is...
How does one format an SD card in a camera like this, or does the camera just do that when you load the card and close the bottom?
Is the white balance setting a default auto, or is there some way to adjust it? What if you want to shift from color to black & white in-camera?
DNG, JPEG or both, how does one set it?
How do you know if you are nearing capacity with the SD card you have installed, or if there is a card error?
These are three I can think of right off the top. I know there are others I'm just not taking the time to consider right now, I'm just curious how this all works on a digital camera with an optical rangefinder and no LCD.
I know digital Leicas are niche products. This model has got to be the niche of niches.
