They often are - at least the base substrates must be different.
Besides that there are traditionally different densities and gamma values targeted for in small and large format black and white. Large format once was mostly used for contact copies, and there also was a escalation of enlarging contrast with growing negative size due to the relatively smaller light source. A matte bulb is approaching point light dimensions in relation to the area of a 8x10", while it is, at twice the negative area, almost diffuse in relation to 24x36mm - and that affects the print contrast from a silver negative.
For modern use where diffuser heads (colour or multicontrast) and scanners are dominant, there is no safe rule of thumb by size any more - you'll have to know the peculiarities of your enlarger or scanner to develop to ideal contrast regardless of format.
