Gerry M
Gerry
a 75mm enlarging lens? Will it enlarge to 8X10 from a 28" enlarger column?
sepiareverb
genius and moron
Most likely- it might be close.
nikon_sam
Shooter of Film...
Probably...but now you've got to be extra careful about any enlarger shake...the higher the enlarger head goes up the more unstable it will get...
There are plenty of decent 50mm lenses out there...
Gerry M
Gerry
As it turns out, the answer is No. At least not on this Meopta Opemus III. Very easy to rotate the column and project to a lower station, tho. I am going to try and fit/adapt my 50/2.8 Schneider Kreuznach to it.
canetsbe
On my Omega C67, yes you can do 8x10. I know because I got sick of switching lenses...
Gerry M
Gerry
I can on my Beseler 23C2 also, but not on this little guy.
nikon_sam
Shooter of Film...
Gerry M
Gerry
There are adapters for the Schneider lens to convert it to a 39mm mount...
Look here...
Sam,
My Componon-S is 39mm ltm. It is too large for this Meopta lens holder (23mm hole). I need to adapt a lens holder/board some way.
