MC Multicoating or SC Single coating?
kshapero
South Florida Man
6:00 PM
South Florida, USA
Voigtlander sells a few lens that can be had in MC Multicoating or SC Single coating? Anybody have some real world experience between the two types? I shoot B/W film in high contrast (Ilford XP2 is my favorite). Seems like Single coating would suit me but I would like to hear others pipe in before a spill the bucks.
Single coated lenses are in principle technically inferior as they are more prone to light loss and multiple reflections, manifested as ghosts and scattering (hazy) light. These problems are more pronounced in scenarios with brightly lit subjects or where there is light extraneous to the required illumination of the subject (e.g. a backlit scene). More highly spaced modern optical systems are usually fully multicoated, which means every optical surface has multiple layers of very thin transparent materials deposited on them (such as MgFl) which enhance transition of light and suppress internal multiple reflections (which lead to ghosts and other problems).
Many vintage camera lenses have only one coating, typically on the first optical surface (the front face of a camera lens for example), and it is a single layer coating. This is because coating technology was more challenging when it was first being implemented on an industrial scale in the post-war era. This however still notable enhanced the throughput of lenses and suppressed other undesirable optical artifacts. As time passed, many artists became attached to the "look" of simply coated or even uncoated lenses. The latter consideration is what has motivated Voigtlander to make single coated lenses (if I understand them, and I think I do).
Voigtlander has a penchant to deliberately replicate history with camera and lens technology, which overall I think is a good thing. However when it comes to coating technology, I personally, don't buy into the single coating idea, but each to his own.
I've used both Voigtlander MC and SC versions, there is very little difference in most situations. At wide open aperture, the SC sometimes displays a bit of glow on bright highlight areas. Unless you compare exact same shots side by side, I don't think you would be able to tell any differences. Stopped down, hardly any noticeable change. Buy the one where you get the best deal.
I had the 35mm nokton SC f1.4 v1 and between that and the nikkor-O single coated 35mm f2, they are the two nicest rendering lenses I've used on black and white film. The nokton on colour film was problematic with flare stopped down and shot into the sun in a way I suspect the MC might not be.
I would tend to agree with the idea that multi coated lenses do better with colour film and single coated lenses are gentler with black and white film.
It is known topic at RFF, worth to google it.
35 1.4 II MC also glows wide open. I can't call it very contrasty lens.
It was thread about this lens here with plenty of BW film images. Can't recall them as high contrast, either.
The Nokton 35/1.4 is kind of vintage by design so it makes sense to “stay in character” and go with the SC version. But as an owner I can attest to the statements of little actualdifference.
