Mini-Review: The New CV 35/2.5 Pancake II
Alan, in your comment on construction, you compare the build quality to that of the CV 50/2.5. What is the reputation of the construction of the 50/2.5?
Thanks for your review. Nice job & superb pictures!
Thanks. The 50/2.5 has one of the builds of all Voigtlander lenses, IMHO. It's solid, heavy (which in my opinion is a good thing) and durable.
Thanks, Alan. I wondered why a 50 mm lens would be priced higher than the 35 mm lens in the same lens line. A 50 mm lens is ususally the lowest priced lens from any company by far. For it to be even close to the price of other lenses is strange; but if Cosina has provided a lens with superior build quality, then this makes sense.
Alan, I'll check it out. Fortunately I get into New York from time to time - one of the few places you can actually see samples of CV equipment & handle them.
BTW, are any other CV lenses known for superior build quality in comparison to the rest of the line.
I think the most people will agree on the following: 35/1.2, 28/1.9 and the 28/3.5. I consider these "second generation" lenses from Cosina... and are much better done.
Thanks again, Alan. I recently picked up an R2, so I'm looking for lenses to go with it. I assume you would include the 50/2.5 on this list?
The 28/1.9 could fill a niche for me. Does the total viewfinder window outside the 35mm framelines approximate 28mm, do you think? Or is the accessory viewfinder a must?
Absolutely. The 50/2.5 is a nice piece of glass. Very sturdy. Unfortunately, I'm not getting much use out of mine... I've limited myself to the CV 21/4 and the new CV 35/2.5. I'm trying to simplify my workflow.
If shooting flash w/28mm or wider while the 28 finder is on the m6 or r2 hotshoe, then you need another hot shoe,does it mean that you don't have TTL ?
Another accessory needed?
