Minolta dimage scan elite f2900 Windows XP problem.
excellent
7:21 AM
I have been trying to get my scanner running for days now and nothing. My scsi card is identified, scanner shows up but Then I try and install the driver/DS elite software on XP and the file opens and freezes every time. It uses installshield, goes to 100 percent and just stops. I have tried on another computer and it worked just fine. Tried unzipping it all to USB and nothing. I just get a DS_elite.dll error. Does anyone know what might be freezing it? I believe the problem is within my own computer because all the software runs smoothly on anything else I open it on. Too bad the laptop wont take a SCSI.
thanks in advance for any tips.
cheers.
SCSI cards are notoriously picky about what hardware they will and won't work with, although the fact that you are receiving a dll error sounds like your problem is more likely to be software related.
You could try a fresh OS install (what fun!); uninstall other hardware drivers to see if you can get it to work; or try different SCSI drivers. Also, if you can get the SCSI hardware operational without installing the Minolta drivers, try a demo copy of vuescan - it should still be able to talk to the Minolta.
Good luck!
