JimG
dogzen
The shutter was sticking on this 7s but after working it awhile it opened up OK. So I replaced the seals, now the shutter is stuck closed at all speeds. I even wrapped it in a heating pad set to low for about an hour. (I heard this can losen any old lubricant that's dried in the shutter mechanism.) Does it sound like I might have got some of acetone (used to remove the old foam) inside the camera causing this problem? Looking through the lens I can see some kind of residue on the shutter blades. Any suggestions?
