thomasw_
I consider an MP, and I have no opportunity to check it in person, so...
1) Can you operate shutter wheel with one finger? I see that M6 TTL, and M7 have bigger wheel, and so it's easier to rotate. How about this smaller wheel in MP? Do you need to use 2 fingers? Also, how smooth is the wheel? Do you need a firm pressure, or it works as a butter, as smooth as an aperture ring on a good lens?
I can understand working in manual mode, but using 2 fingers to change the shutter time makes unconfortable, I think.
2) There is a little eye piece MS-MAG x1.15 (don't confuse with Leica x1.25) which suppose to enlarge the viewfinder a bit. I wear glasses, so I'm thinking about 0.58 version of MP. I also work mostly with 50mm lens, and thought that this would help me sometimes. Now, if I use it, how about these red dots and arrows of the meter?, will I see them in the window, or they will be hardly visible, and obstacled by the mask?
3) How accurate is it with slides? I know that M7 is better in this area, but what's your hit rate with MP?
Thanx,
Kris.
Hi, I have a MP 0.72 and had a MP 0.58.
1. Easily done, not a problem.
2. I used a Megaperl's 1.35x on my MP 0.58 when I shot a 50 or > focal length. It was just lame; I didn't like the dimming effect on the VF at all.
3. Shooting slide film is not a problem as long as you understand some basic metering. I still love shooting Kodachrome 64 with my MP. That being said, I do shoot 95+% B+W film, and if I were to shoot mostly slide film, then I would seriously consider a M7 or ZI.
Hope that helps,
Thomas
