hap
Where can I purchase the full 120 splitter for 127?
This is a problem that I've found with several of my older cameras, all those without a nice, focused, SLR or rangefinder viewfinder, like the larger 4x5 Auto Graflex.
How do you focus in an indoor shoot, or even outside if the subject is close enough? The focal plane is tiny, wide open at f2 or f1.8 (when focus and bokeh is more "interesting"), and without a rangefinder you only have the ground glass. Distance guessing does not work on such confined situations. But even fully open the ground glass look dim withouth a bright light in the composition, and the worst problem is with our 40+ years or more eyes! I can't see a focused image WITH MY GLASSES at less than 30-40 cm away, so the image on the ground glass is small and dark, impossible to see if it's really focused. Only help would be a loupe, but small enough to be used with the already small Ermanox ground glass...
I’m not sure if it could work on your camera...to brighten up your ground glass image~~~~~ I had that issue with an Ansco Automatic Reflex, and things got soooo much brighter and even across the GG when I installed a Hartley Field Lens under the Ansco ground glass. Amazing difference with no visible alteration of the camera. The Hartley Field Lens is a very fine fresnel in lucite, about 1/16 thick. It’s easily shape /size cut with simple hand tools. I mounted mine under the GG in its normal position, with the fresnel surface in direct contact with the GG surface, so focus is unchanged https://www.ebay.com/itm/30355448180...QAAOSwIOheqbx~
Hey Vince,
You prolly are already aware that Shanghai is selling their GP3 now in 127. A bit faster than Pan F
Shanghai GP3 100 Black and White Negative Film 127 | JIANCHENG FILM – SHANGHAI JIANCHENG FILM (shjcfilm.com)
I'm using their 220 version and I like it. Just ordered ten more rolls
Beautiful shots Vincent.
Yes I was aware -- $14.00 for the Shanghai vs $8.86 for the Pan F though. Actually I think the Pan F is perfect for the Ermanox, though admittedly it's a bit of a chore to trim 120 down to 127. The one thing about 100 speed film is I have to watch for fogging, as the light-tightedness of the Ermanox is not like modern film cameras (the shutter design causes light to leak around the curtains). Even with the Pan F I have to remember to replace the dark slide after every shot, thankfully that method has all but eliminated any fogging of the Pan F.
Hey Vince,
That PanF is certainly a perfect match and WOW is it working for you. Amazing stuff. Obviously you are enjoying the process. Thanks for your insights. I think I should shoot PanF+ in my Makina II That will be fun Anyway keep going with this
